One to Many joins
2994
7
02-22-2016 01:16 PM
BrianGober
I have a point layer that is joined to a photos table. One point can have multiple photos. I created the join successfully and published it as a map service, then added the layer into AGOL. For some reason it is duplicating the points. Example - I have one point that has 3 photos. The one point is then duplicated 3 times in the table. Also it is only showing one photo and I want to be able to scroll through the photos in a single pop-up. Is this workflow supported in AGOL? If so, any ideas on what I am doing wrong?
Thanks!
DanPatterson_Retired
the help link... ArcGIS Online Help | ArcGIS
it is a popup you are trying to configure
Configure pop-ups—ArcGIS Online Help | ArcGIS
BrianGober
Yes, the pop-up is configured to show photos, but it will only show 1 photo. Whereas some points have multiple photos associated with them (through the join). I wanted to know if a single pop-up window can support multiple photos.
details for related data are given in the 2nd link I posted on configuring popups... it is too lengthy to copy and paste, but you really need to read it in order to assess whether you want to proceed along that route or take another... It begins in the section on related data
Follow the steps below to configure pop-ups to display related data.  Follow the first six steps in the Configure pop-up section.
BrianGober
Thanks. Yes I have read the related data section. Maybe since I have both a join and a relate, this may be causing the issues of duplication.
That may indeed be the case, if there are duplications, then duplications will appear
JayantaPoddar
You could create a geodatabase relationship class Create Relationship Class—Help | ArcGIS for Desktop , and configure the popup for related data Configure pop-ups—ArcGIS Online Help | ArcGIS , as mentioned by Dan Patterson
Think Location
BrianGober
Yes I have both a relate and a join. Maybe this might be causing the duplication. Thanks.
