New Map Viewer Popup Field Ordering
3998
9
05-18-2021 12:58 PM
AdamMesser1
New Contributor III
Field order is being sorted alphabetically in the popup configuration when a feature service is added to the New Map Viewer. Is there a way to make the map viewer honor the original field ordering as shown in the feature table?
Resorting the original order is problematic as field order is set to facilitate ease of data viewing or entry. Unfortunately, the caveat on the popup configuration mentions "Popups offered in map viewer are not compatible with all apps." This appears to be the same issue that @MarkEastwood experienced with his collector post. We are working on a configurable editing app which apparently does not honor new map viewer popup configurations. I tried using Experience Builder, assuming that the problem may be due to the underlying javascript api 3x/4x compatibility, but EB does not yet have an editing widget. It does not appear the popup reorder is honored in Field Maps either. Given this we are spending time to redo our work to use the Map Viewer Classic unless Esri has recommendations on using the new map viewer for editing wit original field order.
AdamMesser1
New Contributor III
I did a bit of looking for an solution and checked out @KellyGerrow posts as she does such a great job with AGOL articles. For some reason it didn't show up on the community pages when searching, but @TonyViveiros2 asked the same question.
ChristopherBowering
Occasional Contributor II
I'm running into the same thing involving inability to reorder fields in the New Map Viewer and have the desired order appear in Field Maps and/or Collector.  Fortunately, I realized this early on so I did my field arrangements in Map Viewer Classic then saved over the map using the New Map Viewer and did the rest of my work using the New Viewer.  This is definitely a big pain!
by Anonymous User
Not applicable
Just discovered this same problem in Map Viewer - after adding a feature service it changed the field order to alphabetical. Any news on this Esri?
by Anonymous User
Not applicable
Message from Esri Tech support:
Thanks for confirming that my tests replicated the behavior you're seeing. We also had several other tests run, both in ArcGIS Online and in Portal. In each test, we were consistently seeing that New Map Viewer arranges fields alphabetically, in the pop up.
I've since learned this is the intended behavior for pop ups in New Map Viewer.
The Map Viewer offers a lot of new capabilities but there are some differences between the two. For instance the analysis tab is not available in new Map Viewer but it is in old. Another example is the "save layer" button used to be just for the old map viewer but now it is also offered in the new. In some cases, the new map viewer is still catching up to the old map viewer, in terms of capabilities and functionality.
As a workaround, you may decide to stay with Map Viewer Classic, particularly when configuring pop ups and working with forms (e.g., for use in Field Maps, etc.).
Let me know if you have additional questions or if we should explore other workarounds while New Map Viewer plays "catch up," in this instance.
Thanks for the follow up and also for providing feedback on the New Map Viewer and our latest release. Our release team has been hard at work, addressing potential issues that are arising during this early stage following the release. I'll provide your feedback to the development team, so that we can keep aligned with customer concerns and needs going forward. Development is a continuous process, and we're constantly adapting and changing to flow with the needs of the customer, as closely as possible.
To that end, I would also encourage your participation in the Ideas forum within Esri Community. You may already be participating, in which case, thank you very much for taking the time to contribute to the conversation. Ideas submitted there are monitored, voted on by other community members, and many are implemented by development for future releases across all Esri products and solutions.
DebHSF
New Contributor III
I don't understand why it's the intended behaviour. Surely most people have their fields set up in a certain order for a reason? It would make more sense for the original field order to be used and allow people to change it to alphabetical if they really want to.
lzk222
New Contributor III
Intended behavior is developer speech for, "this is not a bug, but it's not high enough priority to improve".
lzk222
New Contributor III
My workaround has been to convert the pop-up value type to String. Use arcade for this e.g. Text($feature.FID). I recommend creating them in the order you want them to display (this isn't confirmed to make a difference). Do this for all the values you'd like included in the pop up. Then select (add) the expression fields in the order you want them to appear (do NOT rearrange them after the selection).
Convert all values to textConvert all values to textSelect the expression values in order you want them to display (New Map Viewer)Select the expression values in order you want them to display (New Map Viewer)
It appears in web app pop-up unalphabetizedIt appears in web app pop-up unalphabetized
MarkEastwood
I have a hard time understanding why this is considered the "Intended Behavior". The workaround that I have found works best is manually reordering the fields in the web maps JSON using the ArcGIS Online Assistant tool. This works but adds a lot of time to our web map development so our organization hasn't switched over to the "New" map viewer for most projects.
Hopefully this gets fixed in the future as there is a lot of functionality that the "New" map viewer has that we would like to utilize.
Tiff
Occasional Contributor III
Not sure if this has been mentioned but there is an ArcGIS Ideas post about this. Just gave it kudos.
https://community.esri.com/t5/arcgis-online-ideas/show-pop-ups-in-attribute-order-rather-than/idi-p/...
