My portal dashboard is showing different formats in two different browsers
1141
12-19-2022 12:57 PM
GeorgeJones9282
hi all, like the title says. I'm having an issue with my dashboard. The top dashboard is opened in Edge while the bottom one is opened in Chrome. I really have no idea what's going on. I recently overwrote the projects layer and maybe that has something to do with it?? Thank youarcpro_edge.PNGarcpro_chrome.PNG
RhettZufelt
MVP Notable Contributor
Could be a caching issue.  Could try this:
Open developer tools on browser:
While in developer mode, right click the reload button, select Empty Cache and Hard Reload:
R_
GeorgeJones9282
I tried that but still didn't work.
GeorgeJones9282
Found the solution: go to internet Properties, click connections, and hit LAN Settings  and uncheck the box corresponding to use Automatic configuration script.
AdrianWelsh
MVP Honored Contributor
George, what you're seeing is a bug. More information can be found here:
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDE0NjgxNA==
We had this same issue and after installing the stale query patch, the issue has been resolved.
