My portal dashboard is showing different formats in two different browsers
1025
12-19-2022 12:57 PM
Labels (3)
GeorgeJones9282
hi all, like the title says. I'm having an issue with my dashboard. The top dashboard is opened in Edge while the bottom one is opened in Chrome. I really have no idea what's going on. I recently overwrote the projects layer and maybe that has something to do with it?? Thank youarcpro_edge.PNGarcpro_chrome.PNG
RhettZufelt
MVP Notable Contributor
Could be a caching issue.  Could try this:
Open developer tools on browser:
While in developer mode, right click the reload button, select Empty Cache and Hard Reload:
R_
GeorgeJones9282
I tried that but still didn't work.
GeorgeJones9282
Found the solution: go to internet Properties, click connections, and hit LAN Settings  and uncheck the box corresponding to use Automatic configuration script.
AdrianWelsh
MVP Honored Contributor
George, what you're seeing is a bug. More information can be found here:
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDE0NjgxNA==
We had this same issue and after installing the stale query patch, the issue has been resolved.
