I am using the Edit web application with a simple web map/feature service with point features.
all is going well and I have figured out how to add points, select a point, and update attributes.
When adding a new point I can place the point, then adjust its location.
but when I select the point, I am unable to move its location. I want to do this in cases where I return to make edits later.
should I be able to adjust the position of a point feature? if so, what click stream is used to accomplish this?
thanks.
