Mixed Content in AGOL is killing us - Please help to Explain best practices
6353
6
11-05-2015 12:06 PM
AaronPaul
New Contributor II
ALL,
We are early adopters of AGOL and have 100's of Web Maps and Services hosted on AGOL.
So we have some experience / methods for navigating "enhancement" pushes to the system.
Unfortunately, we can't figure out an issue with Mixed Content in Story Maps within AGOL.
The issue is when a Story Map has mixed content, portions of the Story don't load or prevent the App from loading at all.
My understanding of mixed content is having sources to http & https within the same App.
We're aware of the settings in AGOL under security that reuire SSL.
We don't require SSL.
Should all content in a Story Map be http or https?
Because having both does not work.
For us this means searching through 100+ maps to ensure they all work or are free of mixed content.
We're searching for a path forward.
Thank you
RupertEssinger
Frequent Contributor II
Please also see this blog post about security and mixed content in Story Maps: https://community.esri.com/community/gis/web-gis/storymaps/blog/2017/06/07/arcgis-blog-an-important-...
Rupert
DavidCrosby
The short answer to the content question is that you should stick with one protocol or the other, but do not mix the content.  Ideally this would be HTTPS.
Here is some documentation for you to consider:
Troubleshoot—ArcGIS Online Help | ArcGIS
Configure security settings—ArcGIS Online Help | ArcGIS
Sharing Web GIS Services? Always enable TLS | ArcGIS Blog
MichaelVolz
Esteemed Contributor
Maybe geo job Admin Tools for AGOL can assist you in this process.
Admin Tools New - Geo Jobe
Just a suggestion as I'm not sure whether your specific problem is covered by their tools, but it might be worth investigating.
LeanndraArechederra-Romero1
New Contributor II
Additionally, if you decide to stick with one protocol you can use the ArcGIS Online Assitant: ArcGIS Online Assistant to update your urls.
ANRGIS
This only lets you change the URL of the overall story/application. It does NOT let you manage individual links within an application.
RupertEssinger
Rupert
