Map Viewer Related Records Portal
5882
14
06-20-2023 10:31 AM
Labels (3)
MelissaSalich
In this blog post, it's showcased how related records are configurable within the pop up in map viewer.
When will related records in map viewer be available in Portal?
LaurenBallantyne
Hi Melissa, I'm happy to say that the team is actively working on adding support for related records in pop-ups for Portal. The feature timeline is by the end of this year. Something to keep in mind when working with non-hosted services is that related records will only work for 11.2 services.
LaurenBallantyne
Kat
Hi Lauren, would this be released as a patch for enterprise 10.9.1 or would the functionality for related records in the new map viewer be available only for 11.1 and up? Is this still on track for the end of this year? thanks!
LaurenBallantyne
Hi Kat, it would be released as new functionality with 11.2 and up, which is scheduled for the 2023 Q4 release.
Adam_blaine
Hi Lauren, I'm using Enterprise 11.3 and can't figure out how to get my related data to show in a popup. Is it still not released?
MarkEastwood
@LaurenBallantyne - "Something to keep in mind when working with non-hosted services is that related records will only work for 11.2 services."
My organization is currently running a 10.8.1 install of ArcGIS Server. We don't use enterprise... will 10.8.1 non-hosted services work when trying to view related records in the new map viewer? If not, is there a release date planned for ArcGIS Server 11.2?
LaurenBallantyne
Hi Mark, ArcGIS Server is a component of ArcGIS Enterprise so it's on the same release schedule and versioning. You'll see support for related records on 11.2 non-hosted services with the 2023 Q4 release of ArcGIS Enterprise/Server.
AndreaB_
Any idea if this is still in the plans for 11.2? Is 11.2 coming out soon? I saw a post that said this was, yet again, pushed to 11.3.
DougBrowning
This post is a year old but any update?  The last AGOL update in June added some more related record stuff but I am not sure it added support for ArcServer services?  We still have 10.9 so cannot test.  thanks
MarkEastwood
Hi @DougBrowning, my organization hasn't been able to test this yet either as we are still on 10.8.1. It would be great to hear some confirmation that this is working on 11.2 or later though as we are planning to upgrade this winter.
