map note symbols in legend
4298
07-03-2013 08:22 AM
BenAller
Is there a way to control which map note symbols show up in the legend of a web map?  I want to create a polygon area map note, and have just the area symbol show up in the legend.  Instead, the legend shows all sorts of symbols (stick pin, push pin, cross, text, lines and areas, even though I'm not using them. Seems like it should only show the map note symbols I'm actually using right?
Ben
MikeMinami
Esri Notable Contributor
There is no control in the ArcGIS.com map viewer. You might be able to open the map in ArcGIS Explorer Online and tweak it. I seem to recall Explorer Online had some ability here but am not positive. (www.arcgis.com/explorer)
Mike
AndrewWallick3
I have the same question. I'm using the standard ArcGIS Online map editor. When I make map notes, I can't get them to show up in the legend.
StefanoToni
It seems that by renaming the layer then runs the command "Hide Legend"
