Map Error In New Chrome Update (128.0.6613.85)
13105
27
08-22-2024 08:16 AM
AaronBrake
I'm a user of an application that uses ArcGIS, and with the new Chrome Update I'm seeing errors when I make a selection to view on the map.
The error I'm seeing is:
Uncaught TypeError: Failed to execute 'uniform4fv' on 'WebGLRenderingContext': The provided float value is non-finite.
at g.setUniform4fv (webgl.js:16:204)
It occurs about 50 times every time I try to make a new selection. The map now doesn't zoom in/pan to my selection anymore, but will just move a small amount while still making the selection.
Is there anything I can do to update, or is this a known issue?
Thanks in advance!
masivFizzy
I have done all of this and I am still  getting this error.
MichaelVolz
Esteemed Contributor
So in the experience at my org, upgrading the javascript app to too high of a version created new issues after resolving the original issue seen at v4.18 (Maybe due to complexity of web app).  I started at v4.26 with many new errors , then downgraded to v4.23 with less errors and finally to v4.21 that fixed the original issue yet did not create new errors in the web app.
MattNicol
Thanks for pointing this out - I updated my original answer to cover this.
Pawanraj
How to update version to 4.30 using npm command?
JonathanWilding
I was able to get my 4.13 app working again by downgrading to 4.11 after I noticed this same issue today.
maurenrivera
Jonathan, my app is using 4.11, but this issue papers. Do you know why? What's your Chrome's version?
maurenrivera
JonathanWilding
i have chrome: "Version 128.0.6613.85 (Official Build) (32-bit)", I just toggled back to 4.13 and the issue came back, then flopped back to 4.11 and it went away again.. I have spent most of the morning today updating and cleaning up a few of my applications to 4.30 but the rollback to 4.11 was a bit of a dirty quick fix and I don't advise it.
JonathanWilding
As an update, i found that the error" Failed to execute 'uniform4fv' on 'WebGLRenderingContext':" came up in a different spot in my test application so the roll back to 4.11 did not completely fix the issue it just moved it to a different spot.
DrewDowling
I just encountered this error on 3 apps running 4.14. 2 of them I upgraded to 4.20 and they are working now.
1 of them is using IdentifyTask class which is removed at 4.20. I downgraded to 4.11 as a quick and dirty fix and now this app is also working, at least so far. @JonathanWilding I'll update this thread if my users encounter the bug on the 4.11 app.
