Maintaining symbology from a FGDB in ArcGIS Online
1062
08-03-2018 06:31 AM
ChristinaHoddinott1
Hello!
I use Collector to collect data (with picture attachments) in AGOL, which I then download as a FGDB and perform edits, and then re-upload/update the FGDB onto AGOL to continue to allow for data collection.
I use FGDB in order to keep the attachments linked to the features... this doesn't seem to work when simply publishing an .mxd.
I have the symbology for each feature stored as a Representation. Of course when publishing an .mxd onto AGOL, the symbology more or less stays the same. However, when I add the FGDB to AGOL the features do not maintain their symbology.
Is their anyway to maintain the symbology of a feature when adding a FGDB? It's the only way (that I know of) I can keep the attachments linked to the features, but I do not want to have to redo the symbology every time I update the data in AGOL (plus, the available symbology in AGOL is lame).
I have an Advanced license, btw.
deleted-user-qpvAI3Fo0MKR
Have you considered using the append tool‌ as referenced here?
ChristinaHoddinott1
That should do the trick! Thank you!
If this works for you, please mark the question as answered
