Location on mobile devices on GeoForm
5416
15
10-13-2016 04:48 AM
DiklaZeidman
hi,
  .I am using GeoForm web application, and recently the application can't locate my location
I tried both in ios and Android /
I checked that the location service in my device is enabled .
will appreciate any ideas
KellyGerrow
Esri Alum
Hi Sergio,
The location button in the Geoform app (and other apps) uses the Geolocation API to prompt the user for permission and find their position. Starting with Google Chrome version 50 and potentially other browsers, some HTML5 web APIs will require using a secure origin like https to work correctly such as the Geolocation API.
This blog explains this in further detail: Increased web API security in Google Chrome | ArcGIS Blog
As a result of these changing standards, the locate button shouldn't be displayed for apps that are loaded via http. There is a bug where the locate button appears with some mobile browsers that is resulting in the error that you are seeing when you try to use the locate button with an app that loads of http. The bug is being worked on for a future release.
Long story short: If you want to use the locate button, ensure that you load the app over https.
-Kelly
KellyGerrow
Esri Alum
This functionality should be working, so I suggest contacting Technical Support to look into the specific issue.
Here are some initial troubleshooting steps:
Try loading the sample geoform app on your phone: https://www.arcgis.com/apps/GeoForm/index.html
Are you able to use the locate button using the different app?
Are you launching the app using http or https? Can you share the app url?
-Kelly
SergioDomenech_Zueco
I have the same problem! I have checked that I can use the location button in the sample geoform app. I have noticed that locate button is enabled in my GeoForm app when I use a httpS connection. Why? How does it work? Thanks in advance Kelly!
KellyGerrow
Esri Alum
Hi Sergio,
-Kelly
Thank you very much for your fast response!
Nowadays I am trying to use the locate button in another app, but I can not see it: GeoForm
I am using a httpS connection. Any idea?
KellyGerrow
Esri Alum
Hi Sergio,
It appears that you haven't enabled the show location option on this app:
http://www.arcgis.com/sharing/rest/content/items/a8cfc331916641508e4beced9c17ca11/data?f=pjson
locationSearchOptions": {
"enableMyLocation": false,
"enableSearch": true,
"enableLatLng": false,
"enableUSNG": false,
"enableMGRS": false,
"enableUTM": false
Try checking the Select Location by My location button to enable the option.
-Kelly
You are rigth! 😉 Thank you Kelly! I forgot that...
MarkJohnson1
Hello All-
I've recently created a really basic app using GeoForm and am having trouble with mobile devices (Android/iOS) being located by the app although it does appear to work on my desktop when I allow access to my location.  I have checked the box 'Locate on load' in the configuration, ensured location is available to both Safari and Chrome, and load the GeoForm as a https. I still get a message 'Location could not be found' when the site loads. When I've tried the demo GeoForm, it does read my location, so it seems like it's something that I've missed. Any ideas?
Mark
PS: The GeoForm URL is
https://calema.maps.arcgis.com/apps/GeoForm/index.html?appid=8369443387ec408b8670de55269eb2ae
KellyGerrow
Esri Alum
Hi Mark,
This looks to be caused be a mixed content issue with the logo in your form. Is there a link to your url from https?
Try removing the logo to see if the location will work on load and let me know if that resolves the issue,
Kelly
