Link to documents on local network server in popup
1199
12-12-2022 04:09 PM
TimHayes3
I have documents that need to be linked to a field in a popup. The path is a local network drive not a url, example:
Z://theimportantdocs/theyarehere
I know that links in popups seems to only accept http (url paths). To get these documents linked should I go into IIS and create a VirtualFolder associated with the above pathname. Then insert the url of the VirtualFolder in the attribute expression? or is there another method? I am not sure, but would a UNC path work?
RhettZufelt
MVP Notable Contributor
Typically, yes.  You use IIS to create a virtual folder to the network drive (can point the virtual folder to the UNC path), then use the https path of the virtual folder(s) for the link.
R_
RhettZufelt
R_
