Layers with Arcade symbology applied won't print
877
02-14-2020 12:15 PM
DavidColey
MVP Regular Contributor
Hello - I can't believe I haven't run into this until now, but it appears that any layer with an Arcade expression defined / used for the symbology will not print.  That is, the layer is not output as part of the map export when using the default AGOL or Enterprise 10.7.1 print service, from either map viewer classic, map viewer beta, or the Web Application Builder print widget
My guess is the user-defined Arcade field name used for display is not recognized by the print service, regardless of where the layer is consumed.
David
Edit - This appears to be a problem with large polygon layers (like a county wide zoning) with an Arcade defined symbology defined.  I did just successfully print a transit-stop layer with some 1500 points that has an Arcade defined expression.
DraganSevic
Hi David,
I have the same issue. Did you contact Esri tech support? Any feedback from them?
Dragan
DavidColey
Hi Dragan, No I did not contact support.  I was waiting for more community feedback, to see if others were experiencing the same issue.
AndrewBowne
I'm running in to the same issues here.  Has anyone found either a resolution or a confirmation that this not supported?
