Layers in a Map Viewer are suddenly in reversed order
796
12-22-2021 01:45 AM
Stefan_Thorn
I have made a map (new map viewer) and suddenly all the layers are in reversed order. Reordering the layers and saving the map did not work.
This behavior has a relation with this issue.
Cant save online feature layer. - Esri Community
RussRoberts
Esri Notable Contributor
Can you share the map? thanks!
Stefan_Thorn
Hi @RussRoberts,
I have identified the reason why this issue occurs.
I also replied about this in  https://community.esri.com/t5/arcgis-online-questions/cant-save-online-feature-layer/td-p/1125266 in this post:
In Map Viewer with an existing map it gives the error:
my experience:
  • when I add an other hosted feature layer, I could save it;
  • but when I renamed this layer I got the error again ;
  • adding again a hosted feature layer, I can save again.
  • trying to save it again without changing, it gives the error again.
Additional, workaround:
  • just adding and new hosted feature layer:
    • Add > choose layer > (+) and than remove it (-)
    • save map
Doing the steps above in a new map, I can keep saving this map.
  • But as I stated, my layers are in reversed order.
  • Doing the add/remove trick to be able to save the map is also messing up the order of the layers. I noticed that all my (group) layers are in reversed order.
  • Doing add/remove again will put the layers in the right order again.
RussRoberts
Can you share the map and layers with russell_jsapi and I can take a look at the possible issue.
