Labels not working in ArcGIS Online
5833
9
08-17-2023 02:17 PM
Sean_Wray
Labels are not showing up on my community facilities layer. I published from ArcPro with labels no luck. I then removed all label configuration from ArcPro and published no labels at all and then tried to turn them on in AGOL and that didn't work either.
When I enable labels on other layers in the map, they work. This leads me to believe that there is something up with the community facility layer.
data is there...
Sean_Wray
So - I'll convert my multipoint feature to point features and label.
RussRoberts
Esri Notable Contributor
Can you share the map published from Pro that is showing the issue?
Sean_Wray
RussRoberts
Looks like those are multipoint and we have an open issue with labeling in the JSAPI to support this. The support ticket to support labels on multipoint is: BUG-0001375864
The error for the labeling was in the browser dev console: "Unable to create labels for layer, geometry type 'esriGeometryMultipoint' is not supported"
I'll create a ticket to hide labeling component in MV to reduce confusion there until multipoint support is added at the API level.
Will
Hi, I can't any reference to this bug (BUG-0001375864) in the support pages, but yet it still seems labeling multipoint geometries in AGOL Map Viewer does not work - what is the status of this issue, is it a bug being addressed, or is it a known limitation with no plans to fix it?  Thanks.
RussRoberts
known limit right now, we are waiting on API support  which is logged under BUG-000137586
Sean_Wray
Mark_Wilson
I have a similar issue - when creating a web layer from a feature class and the labels are not displaying in AGOL Map Scene. Only able to label with the Object_ID field.
Thanks for your help
ElisseDeleissegues1
I am also experiencing published feature layers not showing labels, but my situation is slightly different.
Please see the following:
Labels do not appear when viewed in Map Viewer from FeatureServer (see attached)
https://services3.arcgis.com/fsrDo0QMPlK9CkZD/arcgis/rest/services/COMMERCIAL_USE_PARCELS/FeatureSer...
[{"labelPlacement":"esriServerPolygonPlacementAlwaysHorizontal","labelExpression":"","labelExpressionInfo":{"value":""},"useCodedValues":true,"symbol":{"type":"esriTS","color":[0,0,0,255],"backgroundColor":null,"borderLineColor":null,"verticalAlignment":"bottom","horizontalAlignment":"left","rightToLeft":false,"angle":0,"xoffset":0,"yoffset":0,"font":{"family":"Times New Roman","size":8,"style":"normal","weight":"bold","decoration":"none"}},"minScale":12983.3348645505,"maxScale":0}]}
However, when viewed in AGOL, the labels are showing as expected (see attached)
This is affecting a third party application map
RussRoberts
The labelinginfo is empty
"labelExpression": "",
"labelExpressionInfo": {
"value": ""
and not pointing to  to what the screenshot for the working case would be the expressioninfo pointing to a field or another expression like  "$feature["GIS_COMMERCIALTABLE_CLASSIFICAT"]"
