Is there a list of supported HTML elements within a String field in a feature layer?
1897
08-01-2022 03:25 PM
RogerAsbury
'cause if there is I can't find it. 😞
We have an online application based on the ArcGIS Online Crowd Source Reporter template. I've been given the task of syncing data between it and another application via their APIs. The other app provides a feature rich interface for creating/editing the descriptions, outputting its results in html. However, after a quick test, I've found that using the edit_features() method on a feature, something as simple as changing the string field Details to: <p>This is a paragraph</p> results in a stored string of <br />This is a paragraph<br />.
I'm not performing that change, so I assume something within the ArcGIS API is doing it, and that the <p> tag is off limits for some reason. If the <p> tag, which has been around since the dawn of HTML is not allowed, what else isn't? Or, if it's a shorter list... what is?
Roger Asbury
Analyst/Programmer - Fairbanks North Star Borough
JohnYaist1
Hi @RogerAsbury - See the document here.
Hopefully that helps.
JohnYaist1
RogerAsbury
Sorry I missed your post until now. That's an awesome list! Thanks much.
Roger Asbury
