I've seen a couple videos on youtube that indicate it's not possible. I've used AGOL to edit ine and polygon geometry, primarily in collector. However, I've never tried to move a point's location in AGOL. After uploaded a point file into a Group project in AGOL I noticed a few points were slightly mislocated, probably due to GPS error in the field. When I click on the point I can edit it's attributes, but I'm unable to move the point.
Cheers!
-Adam
It's possible in the new Map Viewer (BETA) to update a single point feature. Here is how I accomplished the task:
FYI Peter Klingman
FYI Peter Klingman
Check out more of what the Map Viewer Beta can do here, connect with others, and provide feedback on the experience:
ArcGIS Online Map Viewer Beta
Thanks Christian! After updating the point's location it appears as if there are two points with the same attributes. However, refreshing the screen I see only the modified point is saved within the map and feature service.
I'll have a read through Beta article you shared.
Cheers!
-Adam
Great! I'm glad this worked out for you.
-Christian
