Is globalID still the recommended primary key for relationship classes now that we can set a unique constraint on hosted layer fields?
876
06-13-2021 01:47 PM
lightpro
New Contributor III
Now that it's possible to set a unique value constraint on hosted feature layer fields is there anything which I should be aware of if I start to use fields other than globalid as primary keys in relationship classes? Being able to use string and number fields as keys would make reading related tables a lot easier.
jcarlson
MVP Esteemed Contributor
Interesting question! I'd like to see more development of relationships in AGOL in general.
However, there are some situations, like in Survey123, where parent globalID → child GUID is the only possible relationship that will function properly in the app. It wouldn't surprise me to find other cases throughout the AGOL system that assume a similar relate.
Honestly, you might post this same thing in the AGOL Ideas exchange, as it's a nice idea. I have a few use-cases that it would work for, and I'd up-vote the idea.
- Josh Carlson
Kendall County GIS
lightpro
New Contributor III
I've cross-posted this to ideas if you want to upvote! https://community.esri.com/t5/arcgis-online-ideas/agol-unique-constraint-for-relationship-classes/id...
Good to know about potential Survey123 issues. I don't really use it but might for my upcoming project!
