Infographic Not Updating
603
09-09-2021 09:07 AM
MichaelKohler
Occasional Contributor II
I have a WAB in AGOL containing 2020 census blocks with the population. We are creating an app that would allow a user to select blocks and assign them to a Council District. I am using the Column Chart in the infographic widget and when I select blocks the chart changes and shows the selected features and when the blocks are assigned, the district numbers in the column chart updates instantly. However, when using a gauge or other template, the only way to get it to update automatically is to set the Refresh Interval on the layer in the web map. So the user would have to make the change and wait for 1 minute to see the change.
MichaelKohler
What happened was I didn't add the layer to the Batch Edit Widget for the layer that the Infographic was using.
