In Mapviewer Beta How do you access the individual sub-layers of a published map service
205
04-16-2021 05:28 AM
KHeulitt2
This question was posted previously but was marked as "solved" and won't allow me to post on the thread.
https://community.esri.com/t5/map-viewer-beta-ques-read-only/in-mapviewer-beta-how-do-you-access-the...
The answer indicates this would be implemented before the viewer was brought out of beta, but I'm still not seeing it now that the viewer is out of beta.  @ChrisWhitmore - has it been implemented?  Thanks!
jcarlson
MVP Regular Contributor
It looks like you can't, at least not right now. In an app based on the "new" generation of web maps, a layer list will allow you to toggle sub-layers individually.
As far as dynamically re-styling the sub layers for a specific map, you'll need to use the classic map viewer for now.
- Josh Carlson
Kendall County GIS
KHeulitt2
Thanks Josh - I suspect you are right, but I am going to wait to see if ESRI responds before marking this as the solution.  Thanks for your response!
jcarlson
Of course! You could always post this as an Idea, too, and then see if it gets marked as "In Product Plan", etc.
- Josh Carlson
Kendall County GIS
