Imagery layers not displaying properly in new map viewer
3480
7
11-02-2022 07:07 AM
JaredPilbeam2
Hello,
I published a digital terrain model and a digital surface model from pro to my AGOL account. They do not display correctly in the new map viewer. However, they look fine in the classic map viewer. The problem is, I want them in the new map viewer because there you can group the layers. Any ideas why the imagery is not displaying correctly?
New Map Viewer:
Classic Map Viewer:
RussRoberts
Esri Notable Contributor
I think the issue is the apply dynamic range and this is applying and you can see that tiling in Map Viewer Classic at times too. You see the exportImage under the console shows the tiling in the image coming from the service.
Disabling the dynamic option I was able to generate a result I think you are expecting
RussRoberts
Can you share the layer showing the issue?
JaredPilbeam2
Hi @RussRoberts ,
Absolutely. I'll just give you the webmap. Open it in the new map viewer to see the DTM and DSM not displaying correctly. The symbology is not even showing up currently for the DSM. I have it set for a multi-part color scheme (blue -red) but it's displaying as black - white.
https://willcountygis.maps.arcgis.com/apps/mapviewer/index.html?webmap=c2b23dda0ba941a4a17397acdbaba...
EDIT: I have a case going with ESRI Support, btw. Case #03189149.
RussRoberts
JaredPilbeam2
Thanks, disabling the DRA did correct the DTM. However, disabling the DRA on the DSM did not correct the coloring scheme. It will still only show black - white.
RussRoberts
That will need a support bug. The dev console is throwing errors and would get the imagery team to look into it.
spandyat25
Hello Russ,
Sorry first time here, couldn’t see an option to start a new post so adding here. Myself and team having issues with imagery services (elevation rasters) not displaying /rendering in a map within experience builder. It doesn’t have much advanced settings or analysis inside. Only few symbology and pop-up options. Services work fine within a fresh basic map. What could be some of the possible reasons for display issues in those cases ? We are looking into few fixes discussed in the forum but also thought to ask. Thanks !
RussRoberts
Do you have the map/layers to share and I can take a look.
