???Identify??? in the ArcGIS Online,
4725
10
02-17-2014 10:55 AM
JamalNUMAN
Legendary Contributor
I couldn???t figure out how the ???Identify??? is working in the ArcGIS Online. I just clicked the features but nothing popped up
[ATTACH=CONFIG]31533[/ATTACH]
What might be the issue here? How the identify is working in the ArcGIS Online?
Thank you
Best
Jamal
Jamal Numan
JamalNUMAN
I noticed you said you loaded it up as a tiled service
To get the attribute table in ArcGIS Online, you will need to reload it to ArcGIS Online as  a Feature Service
Once you have done this in AGOL add the data to an existing map/new map
Click on Content
in the Table of Contents
Click the small dropdown arrow next to the feature
Click Configure Popup
You can then select what information you want to popup when a user left clicks on the feature
Hope this helps
Regards
John
Many thanks Tim and John for the massive help.
It works! the added item must be published with �??feature access�?� enabled or can be shape file.
[ATTACH=CONFIG]31680[/ATTACH], [ATTACH=CONFIG]31681[/ATTACH]
Jamal Numan
