I would like to export arcgis online tables into a excel spreadsheet
3866
8
06-14-2017 07:59 AM
fawnanibert1
I was wondering if you could export a filtered table from arc online to excel as a spreadsheet.
by Anonymous User
Not applicable
This is possible from the item details page:
KaraHarmet2
Hi Fawna,
Did you ever find a way to achieve this?
Kara
by Anonymous User
Not applicable
fawnanibert1
You need to be a LEVEL 2 AND USE credits. Query the data you need and go
to The Analysis tab Extract Data
by Anonymous User
Not applicable
If you are the data owner or the owner has enabled export on the data you can export to excel without using credits from the item details page.
KaraHarmet2
I love that I am able to easily export data to a csv file, but I am referring to exporting emails and names of accounts that log in via the enterprise, under the organization tab.
KellyGerrow
Esri Alum
This isn't possible through the User Interface but is something that we are working on. Until; then you can script an export either through the ArcGIS API for python or with this sample:
http://cloudygis.maps.arcgis.com/home/item.html?id=d3adb69578ba42e9baa0cc6950c08121
-Kelly
DougBrowning
MVP Esteemed Contributor
This free add on will do it.  Used it a lot and pretty slick.
https://marketplace.arcgis.com/listing.html?id=c34019b0623041608df4d06970a7a96a
KaraHarmet2
This is great news! Thanks, Dan!
