I'm trying to setup the search widget or location setting to use with collector.
237
02-04-2020 12:13 PM
ChetShuler
The field is an unique ID and formatted as a double and does not appear in the pull down. So I'm assuming the format is limited to text and integers?
by Anonymous User
Not applicable
Hi Chet Shuler‌,
You are correct, "In the layer, all string and integer fields that do not have coded domains are searchable."
Reference: Configure feature search—ArcGIS Online Help | Documentation
Hope this helps,
-Peter
