How to Use the Same Configuration of a Service Layer on Another Webmap?e?
310
11-02-2020 02:25 PM
EmilyL
Hello GeoNet,
Is there a way to save the service layer's popup configuration and reuse it on another webmap?
Thank you!
Emily
Reply
cartochien
Hi Emily,
Yes, it is possible to do this as long as you are the owner of the layer. Once you're satisfied with how the pop-ups of the layer are configured, hover over the layer in the contents pane and click "..." followed by "Save Layer" at the bottom of the pop-up menu.
The layer will now show the same pop-up configuration regardless of what web map it is on.
Hope this helps!
cartochien
Hi Emily,
Hope this helps!
EmilyL
Thank YOU! 😃
Reply
