How to update a hosted standalone table?
1015
6
07-19-2021 01:34 PM
JoseBarrios1
Hello everyone,
Does anyone know if is possible to update a standalone hosted table using PRO? I can open the table and change a single cell value in PRO but it wont let me use the field calculator to change the values or copy values from a join table.  What do I'm missing?
Thanks for any suggestions!
JB
MikePordes1
make sure the layer is editable, and your named user has access. you may have to join and export to a new hosted layer before calc the fields...
JoseBarrios1
Thanks for a quick reply!
I can manually do changes to single cell values and it works... the problem is changing many values using the field calculator. Exporting to a new table is not an option since the table is the source for many dashboards and Exp. builder applications.
JB
JoeBorgione
...is possible to update a standalone hosted table using PRO?   ...wont let me use the field calculator to change the values or copy values from a join table
What is the objective here?  Are you updating a table or a table joined to a feature layer or what?
JoseBarrios1
The objective is to update the information on a single standalone hosted table using PRO. The table is the data source for several applications.
by Anonymous User
Not applicable
You will need to ensure that you add the table to the map in ArcGIS Pro. You will know that it is there when you see a  table tab at the top of ArcGIS Pro usually in Green. This should open up table-related tools.
JoseBarrios1
Hi Keiren,
I do have the AGOL hosted table open in PRO and I can change the cell values. However it won't  let me use the field calculator to change multiple records or copy data from a join table.
