How to test spatial correlation between two layers
3393
10-08-2015 11:44 AM
WeilinZhou
I have two layers, which visually have spatial correlation. Does anyone know if ArcGIS has any analysis test to test if there is any significant correlation between those two layers?
DanPatterson_Retired
Did you examine or rule out any of the tools in this link
http://doc.arcgis.com/en/arcgis-online/use-maps/perform-analysis.htm
ChrisSmith7
Is that available in ArcGIS Online?
ChrisSmith7
I believe it's just with ArcMap and ArcGIS Pro - not ArcGIS Online! I wanted to make sure they were aware, just in case it was helpful.
