How to print a map showing Aggregate
610
11-20-2024 04:11 AM
MatSmith83
Hi all, I've created a map using the Aggregation (Clustering) tool for one of the layers using ArcGIS Online Map.
When I 'Print' this map as a JPG or PDF the output doesn't include the aggregation, it only prints the individual points.
Am I missing something obvious to make the print output respect/show the aggregate?
Stephanie_F
Hi @MatSmith83 I wasn't able to reproduce this behavior. A case with Esri Technical Support may be the best option to dig into this if you are able https://support.esri.com/en-us/contact. They will be looking to know what your layer source is, if this happens across multiple browsers and with different layers, and if you are using the default print service.
MatSmith83
Hi, thank you for replying.
I assumed this was intended behaviour, and I was just missing an option somewhere...!  I'll go ahead and raise a case with support.
The data is crime statistics from https://data.police.uk if you're interested, a csv file that I add in to an ArcGIS Online Map.
