How to make raster background transparent in AGO map viewer
4487
10
08-17-2022 10:33 AM
HollyTorpey_LSA
We have some drone imagery in TIFF format that we published to Enterprise from Pro and then shared to ArcGIS Online through a distributed collaboration. In the map viewer, the zero-value areas around the periphery of the drone imagery display as solid black areas.
In Pro, we can make the map display the zero values in the raster as transparent so that we can see the underlying basemap. Is it possible to do this in ArcGIS Online as well?
Thanks in advance!
- Holly
Katie_Clark
Ah ok, I'm more used to the interface for publishing to ArcGIS Online instead of Enterprise, but I'm pretty sure you would just select Tile under "Copy All Data" instead of "Reference Registered Data". Does that work for you?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Did you set the raster to display the zero values as transparent in Pro before publishing? I think if you do that, the black areas shouldn't display.
Best,
Katie
HollyTorpey_LSA
Hi @Katie_Clark. Thank you for your response!
We did set the raster to display zero values as transparent in Pro, but we couldn't publish the image from the TOC. For some reason the Share as Web Layer panel that opens when we right click on the layer in the TOC only gives us vector layer options. If we right click on the layer in the Catalog pane instead and select Share as Web Layer, then we get the imagery options as expected. If you have any idea what that's about, I'd love to hear it!
We tried exporting the layer with transparent zero values as a new image file hoping they would somehow be preserved, but that didn't work.
- Holly
Katie_Clark
Oh interesting, I haven't encountered that. Just a guess, maybe it's something related to organization permissions? What type of role do you have in the organization?
Best,
Katie
HollyTorpey_LSA
I'm an administrator, so I don't think it's a permissions thing.
- Holly
HollyTorpey_LSA
@Katie_Clark
Here's what I see when I right click on a raster image in the TOC and select Sharing > Share as Web Layer:
And here's what I see when I right click on the same layer in the Catalog Pane and select Share as Web Layer:
This is all within the same Pro session, same Pro project, both times with Enterprise as my active portal. I'm at a loss!
- Holly
Katie_Clark
Best,
Katie
HollyTorpey_LSA
Well, that sort of worked. It did publish the image, but I can't seem to display it in conjunction with a basemap or any other data or zoom in past the initial display scale. So it's being weird, but maybe that has to do with my hasty configuration when I shared it just now as a test. I'll try again tomorrow with more care to see if it will work. Thanks for the suggestion.
- Holly
Katie_Clark
How many levels of tiles did you build when you were publishing?
Best,
Katie
FédérationQuébecoisedeKite
I'm having the same issue. Looking forward to seeing how this is solved.
Judith
