How to get the mid point (X,Y) of a polyline segment in Arcade ?
7250
11
09-09-2020 05:21 AM
by Anonymous User
Not applicable
Can someone please help me find out how to get the midpoint (x.y) of a line segment in Arcade (ArcGIS Online) ?
I have a road layer with many segmented lines, I want to create a pop up link using the mid point x,y info.
Thank you so much !!
XanderBakker
Esri Esteemed Contributor
Hi KhattabK ,
Not entirely sure if this works, but could you try it?
Function dist(x1, y1, x2, y2) {
    return Sqrt(Pow(x2-x1, 2) + Pow(y2-y1, 2));
// get the geometry
var segment = Geometry($feature)["paths"][0];
// determine length halfway
var halflen = Length($feature) / 2;
// initialize vars
var xcrd = Null;
var ycrd = Null;
var cumlen = 0;
// loop through coordinate pairs in segment
for (var i in segment) {
    if (i > 0) {
        // second coordinate pair, start calculating distance
        var xprev = segment[i-1]["x"];
        var yprev = segment[i-1]["y"];
        var xcurr = segment[i]["x"];
        var ycurr = segment[i]["y"];
        var len = dist(xprev, yprev, xcurr, ycurr);
        var prevcum = cumlen;
        cumlen += len;
        // if past halfway on line
        if (cumlen > halflen) {
            // calculate midpoint
            var restlen = halflen - prevcum;
            var frac = restlen / len;
            var xmid = (xcurr - xprev) * frac + xprev;
            var ymid = (ycurr - yprev) * frac + yprev;
            return "(" + Round(xmid, 2) + ", " + Round(ymid, 2) + ")";
    } else {
        // first coordinate pair
        var xcrd = segment[i]["x"];
        var ycrd = segment[i]["y"];
return "Error";
XanderBakker
Hi KhattabK ,
// get the geometry
// initialize vars
var xcrd = Null;
var ycrd = Null;
var cumlen = 0;
    if (i > 0) {
        cumlen += len;
    } else {
return "Error";
by Anonymous User
Not applicable
Hi Xander Bakker
Thank you so much for getting back to me so quickly ! I really appreciate your help.
This worked like a champ ! I had to add the Meters to Lat Long Function & concatenation to get what I wanted. I will share the source link here for the benefit. Lat/Long unit conversion with Arcade
I was wondering if you know if this is possible in Arcade :
The ability to grab the x,y of the user's mouse click and put it in Arcade for String Concatenation.   (please see snip below)
Thank you so much  Xander Bakker!!!!!
XanderBakker
Hi KhattabK ,
Unfortunately, it is not possible to access the exact location where the user clicked. It would be great to be able to do this. Currently for a pop-up you will have access (initially) to the feature geometry where the user clicked, but not the exact location. No problem for point data, but it will be for polylines and polygons.
by Anonymous User
Not applicable
Thank you so much for the clarification!!
BenjamanGarrett-FG
As I am a novice with Arcade, I am loving this post.  Xander Bakker's post works great, but I am like you and need the Lat/Long.  You have the code link for that, but I am not sure how to add it to the original function.  Can you give me some advice as to where to insert it?
Thank You in advance!
DrewDowling
Are you a wizard?
TanGnar
I want to add to the discussion (and possibly be corrected if I'm wrong). This gets the more precise midpoint of the feature, but doesn't always return a point on the line if the line is not straight. If you don't need a precise midpoint and you want the coordinates to be on the line, I've found the easier option is to get the number of a paths in the geometry object, and get coordinates from one of those paths closest to the middle. If there are 11 paths in the segment, get the 5 or 6th and use those coordinates. then it's always on the line, and the code is simpler.
Bud
If for some reason that midpoint expression doesn't work, this might be an option:
Buffer the line and get the centroid of the resulting polygon. It's kind of like a "poor man's midpoint".
If I recall, that works ok. But I think I remember the point not being the exact midpoint of the line. I forget what the specific issue was. It's probably good enough for most use cases though...
by Anonymous User
Not applicable
In Desktop in Toolbox you can use the Data Management > Features > Add Geometry Attributes.
Add the line you're wanting to determine the midpoint for as the Input Feature and check the box next to Line_Start_Mid_End.  This will add columns in the line's attribute table showing the coordinates for the Start X and Y, Mid X and Y, End X and Y in the same coordinate system as the line.  It doesn't actually create a point but you could then create a feature using these coordinates.
