I'm wondering if other AGOL administrators have found a way to generate a report of storage (and the resultant credits usage) by Group within your org. I would like to find a way to estimate how much storage a particular group needs, and hopefully estimate how many credits they would require to host their content in their own AGOL org.
I have tried the standard reports available, as well as those available from GEO Jobe, but have not found a way to break the storage out by Group.
Joe you could look at something like Qonda Reports which captures all storage info and allows you to report on this by group.
Very slick. I'll keep that in mind if I ever get to the point I can justify the budget.
Anyone else have a more cost-effective solution specifically for Group content? I basically had to make a list of all the feature services in a group and cross reference them in the stock Storage report from AGOL.
You might be able to get the info from Danny Krouks enterprise reporter app. I dont know if it has the relationship between groups and items though (it probably does).
Hey there,
easiest way would be to use the Esri Python API, You can run this from a script, Python window in ArcGIS Pro or a notebook. You can get a group from the group manager then from there query the content for that group.
from arcgis import GIS
gis = GIS(yoururl,un,pw)
content = gis.groups.get(grp_id).content()
for item in content:
dosomething
OK, I can work with that. I just need to add the item size to a list and sum the list. Using something like this...
item = gis.content.search(item_name)[0]
item_id = gis.content.get(item.id)
item_size = item_id.size/1024/1024and
total = 0
total += item_size
return total
I'll see if I can get it working and post back.
