I am trying to create a popup using arcade that shows in descending order the values across four fields in one feature.
for example,
name col1 col2 col3 col4 col5 geography A 10 30 5 40 20 I would like to have access to an array (or other data types) that I can use in a popup. The user would click on a feature on the popup would show the following:
1. $feature.col4
2. $feature.col2
3. $feature.col5
4. $feature.col1
5, $feature.col3
I have less of an issue presenting in popup, but getting the data ordered. I dont think there is a slice or filter available in arcade.
There is OrderBy function, but that goes down a column vs across a row
so far I have the following in my code to get the max value
var col1 = $feature.col1
var col2 = $feature.col2
var col3 = $feature.col3
var col4 = $feature.col4
var col5 = $feature.col5
var max_val = (col1, col2, col3, col4, col5)
My logic tells me that I should remove the current max value and then continue to run max function until I have the last one. But I cant seem to find an easy solution. I can run a long if statement, but hoping there is an easier option.
Thanks
Reza
Solved! Go to Solution.
To expand on Xander Bakker's reply, you could also create a label showing column name and sorted value:
// define Sort comparator returning IsEmpty as least values
function Comp(a,b) {
When(
IsEmpty(a[1]), -1,
IsEmpty(b[1]), 1,
IIf(a[1]>b[1],1,-1)
// create array of [ColumnName,ColumnValue] arrays and sort on ColumnValue
var arr = [
["col1", 10], // ["col1", $feature.col1],
["col2", -30], // ["col2", $feature.col2],
["col3", 5], // ["col3", $feature.col3],
["col4", 40], // ["col4", $feature.col4],
["col5", null], // ["col5", $feature.col5],
// arr = Sort(arr, Comp); // ascending sort
arr = Reverse(Sort(arr, Comp)); // descending sort
// create label showing sorted 'ColumnName : ColumnValue' pairs
var nl = TextFormatting.NewLine;
var lbl = "";
for(var k in arr){
var i = arr;
lbl = Concatenate([lbl, Concatenate(i," : ")], nl);
return lbl;
returns
col4 : 40
col1 : 10
col3 : 5
col2 : -30
col5 :
Have a look at the expression below:
var col1 = 10; // $feature.col1
var col2 = 30; // $feature.col2
var col3 = 5; // $feature.col3
var col4 = 40; // $feature.col4
var col5 = 20; // $feature.col5
// create array and sort and reverse it
var arr = [col1, col2, col3, col4, col5];
arr = Reverse(Sort(arr));
// return list of values
var result = "";
var cnt = 0;
for (var i in arr) {
cnt += 1;
if (result == "") {
result = cnt + ". " + arr[i];
} else {
result += TextFormatting.NewLine + cnt + ". " + arr[i];
return result;
You can use the Sort and Reverse functions to sort an array (descending).
The example above will return this text:
1. 40
2. 30
3. 20
4. 10
5. 5
As always, thanks Xander!!
When(
IsEmpty(a[1]), -1,
IsEmpty(b[1]), 1,
IIf(a[1]>b[1],1,-1)
var arr = [
var lbl = "";
for(var k in arr){
var i = arr;
return lbl;
returns
col4 : 40
col1 : 10
col3 : 5
col2 : -30
col5 :
Thanks! appreciate the extra steps
