How to get all named users in ArcGIS Online
5378
11
06-07-2018 05:17 PM
JosephJose
Am trying to find out how I can get list of all named users in ArcGIS Online account using REST request though I know it provides a visual interface in AdminTools for AGOL
Portal provides a community REST service. Is there something similar for AGOL?
KellyGerrow
Esri Alum
I've fixed the sharing on the script. You can navigate to the link now.
by Anonymous User
Not applicable
Thanks Kelly, I needed it for Javascript. If anyone interested here is the nodejs code to get the users. Unfortunately ESRI REST Endpoint for users is limited to 100 users max per request (again, esri making it more diffucult rather than returning 1000 or so. It's not geometries !!!)
This is a complete Express.js route. You have to use babel to compile and run the code, but you get the picture from the code. if you provide https://your-api/list-users?f=xsl it will generate the XSL spreadsheet
import { getConfig } from '../../config'
import * as winston from 'winston'
// Get the config instance from the module
let config = getConfig()
let auth
let token
let tokenExpires
// const request = require('request');
const requestPromise = require('request-promise');
const rp = requestPromise.defaults({
  'rejectUnauthorized': false,
  'proxy': '<your proxy if required>'
const route = {
  init: () => {
    return new Promise(async (resolve, reject) => {
      try {
        winston.info('Setting up the route for AGOL ...')
        token = await route.getToken();
        if (token.error) {
          token = null;
          resolve('Unable to get the token.')
        tokenExpires = token.expires;
        resolve();
      } catch (err) {
        route.catchErr(err)
        reject(err)
  getToken: async () => {
    const { referer, url, client, username, pwd } = config.agol;
    var options = {
      method: 'POST',
      uri: 'https://www.arcgis.com/sharing/rest/generateToken',
      form: {
        username: username,
        password: pwd,
        client: 'referer',
        referer: referer,
        f: 'json',
        expiration: 21600, // 15-days is max
      timeout: 100000,
      json: true
    return await rp(options);
  listAgolUsers: (req, res) => {
    try {
      console.log(token);
      let func = () => {
        let users = []
        route.getUsers(0, users).then(users => {
          if (!req.query || !req.query.f || req.query.f !== 'xsl') {
            res.status(201).end(JSON.stringify(users, null, 4));
          else {
            // Return XSL
            const excel = require('node-excel-export');
            const specification = {
              username: {
                displayName: 'User Name',
                headerStyle: {},
                width: '50'
              fullName: {
                displayName: 'Full Name',
                headerStyle: {},
                width: '50'
              created: {
                displayName: 'Created',
                headerStyle: {},
                width: '50'
              modified: {
                displayName: 'Last Modified',
                headerStyle: {},
                width: '50'
              level: {
                displayName: 'Level',
                headerStyle: {},
                width: '50'
              userLicenseTypeId:{
                displayName: 'User License Type',
                headerStyle: {},
                width: '50'
              disabled: {
                displayName: 'Disabled',
                headerStyle: {},
                width: '50'
            const report = excel.buildExport([{
              heading: [],
              specification: specification,
              data: users
            res.attachment('AGOL-Users-export.xlsx');
            res.send(report);
        }).catch(err => {
          res.status(404).json(err);
      // Check if the token is still valid
      if (!token || !token.token || new Date() > new Date(tokenExpires)) {
        route.getToken().then(result => {
          token = result;
          tokenExpires = result.expires;
          func();
        }).catch(err => {
          console.error('Unable to get the token');
          route.catchErr(err, res);
      else {
        func();
    catch (e) {
      res.reject(e)
  getUsers: async (start, users) => {
   return new Promise((resolve, reject) => {
      const options = {
        method: 'GET',
        uri: config.agol.users.url,
        qs: {
          token: token.token,
          f: 'json',
          num: 100,
          start: start ? start : 1
        json: true
      rp(options).then(results => {
        const total = results.total;
        let current = 1;
        let promises = []
        while (current < total) {
          const opt = {
            method: 'GET',
            qs: {
              token: token.token,
              f: 'json',
              num: 100,
              start: current ? current : 1
            json: true
          promises.push(rp(opt));
          current += 100;
        let users = []
        Promise.all(promises).then((xresults) => {
          xresults.forEach((r) => {
            let extract = r.users.map(u => {
              return {
                username: u.username,
                fullName: u.fullName,
                created: (new Date(u.created)).toString(),
                modified: (new Date(u.modified)).toString(),
                level: u.level.toString(),
                userLicenseTypeId: u.userLicenseTypeId,
                disabled: u.disabled
            users = users.concat(extract);
          resolve(users);
      }).catch(err => {
        reject(err);
  catchErr: (err, res) => {
    winston.error(`agol.js: ${ err }`)
    if (res) {
      res.status(404).json('Error')
export default route
