How to edit the ESRI bottom credits on Experience Builder Maps.
1571
11-05-2024 12:43 AM
Renata
Dears,
I am creating a map in Experience Builder ArcGIS Online and I would like to ask if it is possible to edit the ESRI credits at the bottom of the map. I will insert a screenshot to make it easier to understand.
Thank you.
ChristopherCounsell
MVP Frequent Contributor
These credits are derived from the service layer in the Basemap. It's not possible to directly edit them and including them is part of the terms of use.
In ArcGIS Pro you can insert dynamic text for service layer credits, moving them off the map, but technically we are still required to include a credit to the service providers on the layout.
In ArcGIS Online, you can create a custom Basemap with layers that do not have service credits. Likely to be ones that you publish. Follow the below to add and remove layers from the Basemap group;
https://doc.arcgis.com/en/arcgis-online/create-maps/choose-basemap-mv.htm#ESRI_SECTION1_5C28F0CDBF18...
ChristopherCounsell
Renata
ChrisWhitmore
Hi @Renata, additionally you can add attribution to the item page for layers contained in the map..any maps that include those layers will show the credits set on the layer items.
Cheers,
Chris
ChristopherCounsell
Thanks @ChrisWhitmore. I see users trying to remove it so much that I forgot to make clear we can add to it as well!
Renata
