How to download feature service from AGOL with attachments?
5323
11
11-22-2015 06:23 PM
FelixPertziger
In the past I was able to use REST/Create Replica service for that.
It still downloading features and attachments, however with broken link between two, i.e. field REL_OBJECTID in related table is populated by {00000000-0000-0000-0000-000000000000}.
Is this something to do with expiry of my account? Or something has changed and I have to download/consume credit points through analysys option?
Regards
Felix
JakeSkinner
Esri Esteemed Contributor
Hi Felix,
The following tool will allow you to download a feature service with attachments:
Download ArcGIS Online Feature Service or ArcGIS Server Feature/Map Service
FelixPertziger
Hi Jake
thank you very much but it gives me
URL is incorrect.  Or, Service is secure, please enter username and password.
Help please. Is this about EXPIRY of my account?
JakeSkinner
If your ArcGIS Online account is expired I don't believe you will be able to access the service.  If you copy/paste the URL into a web browser, are you able to access the REST directory of the service?
FelixPertziger
Yes, I am. Moreover I can view features and attachments in desktop.
JakeSkinner
If the service is shared with 'Everyone', can you provide the URL?
FelixPertziger
It is shared with my team only. I am prepared to give you my user name and password. How can I do it safely?
FelixPertziger
Jake
I have my credits back, it 2500 total. Still nothing happening. I am unable to use your tool, extract data task is not working either.
Are you able to help?
Rgards,
Felix
JakeSkinner
I'm not sure what is wrong with the service.  The tool does work, you can try it on the following feature service if you like:
http://services.arcgis.com/dlFJXQQtlWFB4qUk/arcgis/rest/services/ResidentialBuildings/FeatureServer/...
One thing you can try is make a local copy of the feature service in ArcMap.  You can do this by first signing into ArcGIS Online with Desktop > and then add the service from 'My Hosted Services' in the catalog window.
FelixPertziger
Well, not on my machine
Executing: DownloadService true false "http://services.arcgis.com/dlFJXQQtlWFB4qUk/arcgis/rest/services/ResidentialBuildings/FeatureServer/... " false false # # D:\Scratch\EBOP.gdb\buildings true #
Start Time: Thu Nov 26 08:15:09 2015
Running script DownloadService...
Generating Token
Failed script DownloadService...
  File "C:\URS-Data\URS-Data\ESRI\Tools\My Toolboxes\Download\Download Service with Attachments.py", line 48, in <module>
    response = urllib2.urlopen(req)
  File "C:\Program Files (x86)\Python27\ArcGIS10.2\Lib\urllib2.py", line 127, in urlopen
    return _opener.open(url, data, timeout)
  File "C:\Program Files (x86)\Python27\ArcGIS10.2\Lib\urllib2.py", line 410, in open
    response = meth(req, response)
  File "C:\Program Files (x86)\Python27\ArcGIS10.2\Lib\urllib2.py", line 523, in http_response
    'http', request, response, code, msg, hdrs)
  File "C:\Program Files (x86)\Python27\ArcGIS10.2\Lib\urllib2.py", line 448, in error
    return self._call_chain(*args)
  File "C:\Program Files (x86)\Python27\ArcGIS10.2\Lib\urllib2.py", line 382, in _call_chain
    result = func(*args)
  File "C:\Program Files (x86)\Python27\ArcGIS10.2\Lib\urllib2.py", line 531, in http_error_default
    raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 400: Bad Request
Failed to execute (DownloadService).
Failed at Thu Nov 26 08:15:11 2015 (Elapsed Time: 1.94 seconds)
