How to delete records form a table that is used in a dashboard?
684
09-15-2024 10:10 AM
BenjamenWetherill
I have a table in AGOL that is referenced in a dashboard.  When I updated the table by adding features, I inadvertently duplicated all of the existing records in the table because my source file had all records.  Now, I can't figure out how to remove the duplicates from the table in AGOL.  The Update Data function does not allow me to overwrite the entire table.  If I recreate the table from scratch or share it from ArcPro, I'm afraid I will lose all of the configuration settings I have done in the dashboard.
RichardHowe
If you add the table into ArcGIS Pro you should be able to edit it like any other table (add, delete, update individual records).
Just search your portal in the Catalog pane to find it
RichardHowe
BenjamenWetherill
This works perfectly.  Thank you!
