How to connect to ODATA source in Map Viewer
3789
8
05-10-2021 03:06 PM
by Anonymous User
Not applicable
Hello -
I was wondering if there is any documentation for how to add a web layer from an ODATA source to ArcGIS Online? If the ODATA source requires authentication (username + password), is there a way to do this? I only see the option to add the URL for the API.
Do you need the ArcGIS Data Interoperability extension in order to connect to a ODATA source? Or does this need to be done in JavaScript?
Thank you!
CharelvanDijk
I have this question to!
ChelseaRozek
MVP Regular Contributor
I'm also interested in hearing if anyone has found a way to use an odata source.
JohnBickmore
I am also wanting to do this?
BasuMathapatiOz
I have the same question, any answers please ?
jzcgis
Any info on this?
BasuMathapatiOz
While I could not find the way to connect and extract oData web services within ArcGIS environment.
Now, I have set up an FME ETL process to do the same.
JeroenBaltussen1
Odata should  be in supported data formats and
the new option: joined hosted feature layer views in arcgis online
RachelSinclair
Hello, is there a solution to this yet? I'm interested to do the same thing.
