How to color whole country instead of a dot from CSV data?
1261
12-09-2018 12:43 PM
SabrinaRoshni
i have created a layer by importing the following data in a CSV fie;
resource,Location
10,DE
30,RU
40,FR
then applied style Type (unique symbols) but it only puts 3 dots in the center of three countries.
I need to color the whole country instead of dot like it is done here: http://www.arcgis.com/home/webmap/viewer.html?webmap=83f3180124454de7b0346cedeb78a57d&extent=-74.128...
thanks for any help!
best,
KellyGerrow
Esri Frequent Contributor
Check out this blog which has some instructions on how to join a table (CSV) to a polygon layer.
Table to App - Part 1: Create Data
You will need an ArcGIS Online subscription to use this tool, but it should get you up and running.
Kelly
JohnPlunkett
Hello
If you add data as a CSV - a point is generated.
You would need to acquire a polygon feature class with the countries and add the field with the information you desire.
KellyGerrow
Kelly
SabrinaRoshni
Thanks a lot Kelly! Exactly what I was looking for
Best,
SabrinaRoshni
Thanks John, got the idea
