How to clear / reset app after using "Save to layer" on the Network trace widget?
704
12-05-2016 07:33 AM
DavidBoiano
I have a Network Tracing application set up. During testing, I tried out the "Save to layer" button on the Output tab of the Network trace widget. It saved successfully and added the layer to the Layer list.  Trouble is, I can't figure out how to remove it or reset the application back to default.
Any ideas??
Thank you!
David
by Anonymous User
Not applicable
Hello David Boiano,
Are you using an application template or are you developing the application yourself? If it is public could you please share the link to your application?
Thank you,
Katie
DavidBoiano
Hi Katie,
Thank you for your reply. I am developing the app myself using Web AppBuilder 2.1 and unfortunately it is hosted internally here at my organization. I came up with one solution of manually deleting the features that were added to the OutageDetails map, but I'm not sure if this is best practice or if there is a preferred method.
David
