How to change the label in the edit tab in map viewer?
2858
11-04-2024 08:11 AM
KellyTaylor
Hi all,
There must be a really simple answer to my question but I can't seem to figure it out. When you are editing in Map Viewer and you have multiple features from the same layer selected, a list of those features pops up, and I'm trying to figure out how to change the way those features are labeled.
In the screenshot below, my features are labeled based on a useless field that will show "normal" for almost every single feature. I'd like to change which field is used, such as inspection date and/or inspected by.
KenBuja
MVP Esteemed Contributor
That's controlled by the Display Field when the service was published. I can't see a way to change that in AGOL, but you can change that in ArcGIS Pro. Open up the Layer Properties dialog and select the Display tab.
For example, this is how one of my services was set up in ArcGIS Pro
and this is what the Rest service shows
When I edit it, all the points show the Habitat field
lmurrayADOT
FYI, I submitted this to ArcGIS Ideas for a possible enhancements.  This should be something that can be controled within ArcGIS Online.  https://community.esri.com/t5/arcgis-online-ideas/edit-display-attribute-header-in-edit-tab/idi-p/16...
