How to avoid reloading map image layer every time a change is made?
427
03-01-2021 07:39 AM
Labels (3)
RandyMcGregor3
I have just added a field to a layer that is part of a map image layer, and I do not see the field in the web map. I know from experience that if I reload the layer, I will (probably) see that field, but I would rather avoid reloading this layer. I have made some customizations that I would rather not have to redo.
Is it possible to see the changes made to data in a map image layer without reloading it into the web map?
Thank you,
Randy McGregor
