I have a table on ArcGIS online that has a mix of point features, some have geometry assigned to them and display on the map while others do not have a point assigned to them. I would like to be able to select a given row and manually drop a point to be associated with that row.
It looks like this will work in ArcGIS Pro if I select the row and use the Replace Geometry tool in the Editing panel. Is there a way to perform this edit directly on AGOL?
Thank you for any suggestions
