I have found the HTML coding once before for this, but I am trying to add the photo before or above my attribute lists within the popup for a web map. Essentially, when I click on a building outline, I want to see the photo first. If someone could provide a link to the custom popups to address this or the HTML code that needs to be put in the custom setting. I would greatly appreciate it!
I got mine to work by just using an img tag in the HTML Source section of the custom popup configuration window. Here's the code that I used:
<img alt="picture" src="{Images}" style="width:231px;height:158px;" />
Where {Images} is the field that contains the URL of the photo.
Hope that helps!
Thank you so much! That is exactly what I was needing!
Great, glad I could help! It would probably be good if you could mark this question as "answered" for the forum.
