How to add JSON opertaional layers info on Arcgis map
300
02-19-2018 08:51 AM
RuthKerr
I am trying to load operational layers data from the following JSON with no luck.
So far I tried the following:
  • add it as a graphic layer by using graphicLayer = new esri.layers.GraphicsLayer(); graphicLayer.add(json); map.add(graphicLayer);
  • tried to normalize it and add as a graphic using normalizeUtils.normalizeCentralMeridian
Is there something I am missing, for reference I am trying to follow this example http://resources.arcgis.com/en/help/arcgis-web-map-json/index.html#/ArcGIS_feature_service_operation...
Its my first time with Arcgis, I have a sample JSON of a previously drawn line on the map that I am trying to load with no luck. Here is a JSFiddle of what I am trying.
Tags (3)
RobertScheitlin__GISP
Ruth,
   It is likely the json format. Can you share your json data or your Fiddle (it did not make it the first time)?
