I want to try the new AGO Clustering option but for some reasons, I'm not able to access it in any of my services published with AGS 10.3.1
I've added two services in AGO :
Both services are feature ones, in WGS84, respect the considerations mentioned in the ESRI documentation.
What is wrong with my service ?
Thanks.
Alex.
PS : I'm not allowed to share my service, here are the specs :
Solved! Go to Solution.
Here's another good read about pagination: Error: Pagination is not supported, it shows you where to look in the REST service to see if pagination is supported. It should work for you if you upload to AGOL - I was able to get it to work with our data. Another reason to (hopefully) upgrade SQL soon.
Are you logged into an AGOL organizational account?
Have you checked the considerations for configuring clustering?
- Clustering is supported on hosted point feature layers, ArcGIS Server 10.3.1 and later point feature layers, CSV layers, and feature collections.
- Clustering is not supported on multipoint feature layers.
- Clustering is only supported for up to 50,000 features in a layer.
- To configure clustering on a point layer, the map must be in the WGS 84 or Web Mercator coordinate system.
- Clustering is disabled during an edit session.
Hi Jayanta,
Yes, my service respects all of these requirements, that's why I don'T understand why it doesn't work.
Thanks.
Alex.
Try adding FeatureServer URL (".../FeatureServer/0") of the REST service, not the "...MapServer" one.
It's what I did, my url is : https://rtftwebarcgis.ae.riotinto.org/arcgis/rest/services/test/testCluster/FeatureServer/0
What is the version of ArcGIS Server that you have?
Version is 10.3.1
I'd suggest getting in contact with https://community.esri.com/groups/technical-support?sr=search&searchId=a4cbe1ad-130b-453f-b376-9f3c8... to look into the specific issue.
What is the version of the DBMS for your Server 10.3.1? According to Diana in this blog (scroll down to discussion), it must support pagination for clustering to work. I also tried clustering with my feature services and they don't work (I believe) because I am still running SQL Server 2008 R2. This version of SQL doesn't appear to support pagination.
Hi Brian,
Oh my god, I never read the comments of that page, stopped at the end of the post !
Thanks for the clue. Indeed, we use SQL server 2008R2.
I'll test if with features hosted in ArcGIS Online.
Thanks.
