How do you remove thousand comma separators on ArcGIS web map labels and tables?
639
5
01-10-2020 08:51 AM
Jan_VincentPunzalan
How do you remove thousand comma separators in labels on ArcGIS Online web maps? I know you can remove them in the pop-ups, but how do you remove them in the labels and tables? How would you be able to do this without having to write an arcade expression?
KenBuja
MVP Honored Contributor
When you configure a field in the popup to change the "Use 1000 Separator" option, that change is reflected in the table immediately. For the labels, if you've already created them and then changed the separator option, you have to click on "Manage labels" and then click OK to resync them.
Jan_VincentPunzalan
I think that about does it thank you!
XanderBakker
Esri Esteemed Contributor
Hi Jan Vincent Punzalan ,
Could you mark the post by kenbuja as the correct answer?
KellyArmstrong
Why would one have to do that for the labels to resync?  Shouldn't that automatically happen after the "Use 1000 Separator" has been unchecked, saved, and the map refreshed?  So, one has to actually take one more step and go to "Manage Labels" for the labels to actually refresh and label correctly.  Seems totally illogical and could be taken care of in ESRI's code fairly easily.  Seems like a bug to me....
JacobMcCoy
This workflow did not work for my data
