How do I make Drone2Map, Collector and ArcGIS Online work together?
143
07-05-2019 09:16 AM
Suzanne
New Contributor III
I'm using Drone2Map and Collector for field surveys.  Drone2Map does not support Web Mercator Auxiliary Sphere for the GCPs and the Collector map is made in ArcGIS online that has a default coordinate system of Web Mercator Auxiliary Sphere.  I have tried to add my own basemap to Arc GIS Online with the coordinate system I need--but when I try to share it the warning comes up that the web layer will used WGS 1984 Web Mercator (Auxilairy Sphere). I found a basemap in the portal that was GCS WGS84 and used that as a basemap and it worked in Collector (which I could use in Drone2Map, but I would really like UTM), so does anyone know where a UTM basemap of California is already in the portal, or how I can add a basemap with the coordinate system I need? Thank you very much!
