How do I download all ArcGIS Online attachments from a hosted feature layer made from a Survey123 form?
16612
21
07-20-2020 01:13 PM
KaitlynAbrahamson
I have seen some work on this question on GeoNet before, but I absolutely can't get my attachments from a hosted feature layer downloaded.  I have a Survey123 feature layer with a photo repeat that I have tried exporting to a file geodatabase without success.  All I get is the standard 1KB file that will not unzip.  I tried creating a replica without success as well; I keep getting error messages.  I also tried using a notebook with script I've found on this site, but I am so new to Python, that I have not been able to get it to work.  Please help!
Katie_Clark
MVP Regular Contributor
To confirm, you followed this workflow to try to download the fgdb? This is the only one that's always worked for me...
How To: Download attachments from a hosted feature service
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
KaitlynAbrahamson
This is what I followed, but I can never get a final link for download.  I always run into errors like the one below.
"Error in creating runtime geodatabase."
KaitlynAbrahamson
I was able to create a replica, but I'm not sure where the photos are actually saved, let alone the sketches from our Survey123 crew in the field are.  How do I access the actual photos and know which points they belong to?
Katie_Clark
So do you have the data within a file geodatabase? If so, there should be an attachments table that will contain the photo data.
Best,
Katie
- Simon Sinek
KaitlynAbrahamson
These is an attachments table, but I want to see the actual photos and the exif data.  How do I see those?
KaitlynAbrahamson
Is there a way to actually save jpg files that I can open and see the photo?  That's really what I need.
JakeSkinner
Esri Esteemed Contributor
Kaitlyn Abrahamson‌ you can use the following code to export the images:
import os, arcpy
# Variables
tbl = r"C:\Temp\Python\Test.gdb\Graffiti__ATTACH"       # Path to attachment table
fldBLOB = 'DATA'                                        # Field name of Blob data type field in attachment table
fldAttName = 'ATT_NAME'                                 # Field name in attachment table that contains attachment name
outFolder = r"C:\Temp\Python\Attachments"               # Output folder to export attachments to
with arcpy.da.SearchCursor(tbl,[fldBLOB,fldAttName]) as cursor:
   for row in cursor:
      binaryRep = row[0]
      fileName = row[1]
      # save to disk
      open(outFolder + os.sep + fileName, 'wb').write(binaryRep.tobytes())
print('Finished')
KaitlynAbrahamson
Yes!  I finally got it to work!  Thank you so much for your help.  It was invaluable.
ScottDeNeicev1
Is there a way to connect to the hosted feature service without having to download the filegdb first?
