I have two fields that are numbered lists. I want to create conditions that change the unique symbol based on a combination of these fields. Basically, if a condition in Field A is true, use Field B to set the unique symbol, otherwise use Field A.
This is what I've come up with in for a custom expression:
var underground = 0
var aerial = 1
var existing = 2var type = $feature.Route
var status = $feature["Segment_Status"]if (type == underground){
return DomainName($feature,"Segment_Status")
else{
return DomainName($feature,"Route")
This almost seems to work. It combines most of the items in both lists so that I can customize the symbols (however, Underground is missing):
When I attempt to edit one of these fields from the Pop-up on the map, all of the symbols disappear and the map looks empty except for the labels that remain.
To add detail to the question; How do I combine two lists to create unique symbols that list all of the symbols and does not make all of the symbols disappear when one of the fields is updated?
I may be going about this all wrong. Any help would be appreciated!
