How can I set the OPENING extent of a single map or service in ArcGIS Online based on values (name) of school location using a hyperlink?
2358
07-14-2016 05:23 AM
NathanWood2
New Contributor III
4 - Cluster Map
To provide a Webmap of Current School Locations or Zone Boundaries in a dynamic format, while also providing links from School websites.
We are trying to replace a bunch of static maps that would pop in new browser windows with ArcGIS Online content/service.  From a particular school webpage they would select or click on a hyper link that would take the user to a WebApp that centered around their school, without user inputs once they had clicked on link.
KellyHutchins
Esri Frequent Contributor
Nathan Wood​  You can do this by making a small update to your web map. In your current example you add the school to the map using the  map service but instead try removing that layer and adding it as a feature layer where you point directly to the sub layer id. For example add a layer to your map from the web and specify this url:
http://gis.mnps.org/arcgis/rest/services/MNPS_Zones/MNPS_Current_School_List/MapServer/0
Once you've done that you can use the Basic Viewer configuration option to configure the url param to search the specified layer and field. Here's an example where we select the MNPS Current School List and pick the CLUS_NAME as the search field.  We also define the name of the url param - this can be anything you want it to be - here we used cluster.
Then if you append the cluster url param with the value you want to search the app will zoom in to that location when it starts. In this example we search for cluster=Hillsboro
In the future we'd like to be able to support choosing url search layers from a map service instead of requiring that you add a feature layer.
NathanWood2
New Contributor III
here is a look at school page with highlighted links for old pdf maps.
KellyHutchins
NathanWood2
New Contributor III
Kelly
Thank you for your timely comment or reply.  That will be most helpful.  With that setting change, lat/long extent or zoom level added to parameters we are on our way, see below...
http://mnps.maps.arcgis.com/apps/View/index.html?appid=15df0f15d87948d1a61eda5b7248018e&level=14&ext...
